I'm starting to get things in line to do my first transmission swap. Right now I have a TH350 that leaks about a quart of fluid a week. Most of my driving is highway driving and the car has 3:73 gears so I'm swapping to a 200-4r. Motor is an Olds 350 also. This list of things I know I need so far is,
Transmission
Torque converter (lock up)
Trans cross member
Torque converter lockup switch
Speedometer gears
Speedometer gear housing
Dip stick
Carburetor tv cable brackets.
Anything that I'm missimg? Any suggestion on brands and such is welcome also? So far I think I'm going to be going with a jegs brand transmission and gforce crossmember. The jegs transmission is the best price I can find. I was looking at monster transmission bit read lots of bad reviews of them. Thanks for any input in advance. I'm kind of nervous doing this swap but I'm never going to learn if I don't do it. I think with the resources available on this site, google, and a couple of friends it should go pretty easily.
Transmission
Trans cross member
Speedometer gears
Dip stick
