As long as you are not pushing 400+ ft/lbs, the forward drum should be OK. A 2400 stall sounds perfect for your combo. Sounds like a good deal for the trans. I would get a trans gauge and check pressures after install. Mine shifted soft after install, pressures were low in drive and OD. I swapped pumps since I had fresh one with hardened rings, stiffer spring, 13 vane rotor and .500/.296" boost vlaves. The 13 vane is controversial whether it does any good, some say it is even worse than the 7 vane, being weaker. I added the .555" boost valves to get pressures acceptable, from 185 to 215 psi. It might have meant a shortened life if I didn't check pressures. Now drives stock under light throttle and the 2300 flash stall gives a nice launch and firm shifting but not harsh under heavy throttle . One thing you need to upgrade in the stock pan, the sheet metal pan is the best. I have the Hughes pan, seeps a small amount no matter what I do. I run the bottom feed 4L60E early style filter with it. I believe that pan now comes with the bottom feed 700R4 filter. The minimum that should be done is a quart over full with the stock pan due to the stock filter sucking from the top.
