Yes, the port is where he mentioned and you can drive with it clipped under the wipers, just route away from exhaust. The Hughes pan has a drain plug. I believe you thread a temp gauge sender in the pan. Why don't more people run the early 4L60E filter? Fits the pan better and is plastic, so no shorting out the switch, that is why I run one. If you push your car hard, a deep pan is good insurance, I take mine down the 1/8 mile. Dr Dan Mascal, builds these trans and swears by the sheet metal pan, pick up at the back of the pan, to help them live. Dan thinks the Hughes pan with the bottom feed filter is good into the 12's.I would also add a big trans cooler, I run two mid size coolers, did that so it wouldn't block air flow to the rad as much, one under the head light, not sure if it is a good idea or not.
