got the fan studs in yesterday (that was fast!) so I figured I'd swap them out and go for a spin. Sure enough these are longer and I'm MUCH more comfortable with how they fit. Here's a pic with the 3 different ones I had. The top is the ones that came out, they worked fine, but like I said were grungy and the threads had issues. The 2nd is the Dorman. Same length, but
notice the offset? There's the problem. It doesn't look like much, but with the lock washers on I could only get about 1/3 of the threads on the nut engaged. Without the washers they were still not all the way through the nut. Nope.
The bottom one is the inline tube version, part # (I think) is
INL14863. Much better. No question they fit. And they did with room to spare. Wasn't cheap, $12 shipped, but well worth the peace of mind.
I am starting to get concerned I may have a tiny head gasket leak in one of the cylinders. When I first started it up it sounded like something was clunking around (different than my fan shroud issue) but quickly went away, then it dawned on me sh*t that might have been misfire from coolant. I could never get it to do it again, so I'll wait and see after a few days if it does it again.
I still need to change the temp sender. It seems to get warm really fast (see above, hm) but then you can watch the t-stat open and it goes back down, then on the highway warms up just the slightest.... Still I measure the water neck with the IR thermometer and its right at 190*. *shrug* Have to get that old sender installed.
Took her down the highway at 70mph about 5 mi, filled up the tank, and made it home again without anything weird happening. Didn't abuse her but put the gas down a little. Still drives good all things considered. I forgot how much fun getting to about 45mph was, but after that its all in 4th, pulls ~3K RPM at ~75mph. WAAAAAAAAAAAAAAAAAAAA.
