So I got all the power steering box and pump crap swapped out. Took it for a drive and it's a bit firmer to turn than the old one. The old system could be turned with one finger and the new system not as easy. I welded on some stainless exhaust tips because the exhaust shop had cut them off at an angle. It looked like motorcycle exhaust angle cut so I recut them straight. The tips are fit over the pipe and have a rolled edge. I then focused on the carb. It still smells fat and the plugs are black. I went from a 62 jet to a 59 and put in my 7.5 power valve. I re checked float levels and rechecked my air bleeds with a gauge. What the hell makes a Holley 600 run rich at idle after doing all this? I've always been a Holley guy and have always been able to fine tune them. This is the first one I've had do this. Maybe I need to check the voltage to the HEI. I don't need a big debate/discussion here on Holley vs Edelbrock either
