HAFRODs 78 Aeroback Salon build
If you need another set of hands tomorrow just shout. I think a couple others will be rolling in earlyish and would probably lend a hand also.
Sent from my iPhone using Tapatalk Pro
Bar50 is coming this morning to help. I had a hell of a night with not much sleep from muscle cramps I'm robot walking this morning but I'll limber up in a bit. See you guys tonight
It was a thrash but it is running. Got to thank Bar50 for coming and helping for half a day. The only issue I have is the temp sender. The centerbolt heads have a small coolant port. The old school perimeter bolt heads have a big port. I put in a brand new coolant temp sender but it's not reading at all. I have another sensor I'm going to swap out in the morning (5 hours from now).
Man your a machine!
The cruise was cool. I filled up in Joplin, MO. My gas stop had ethanol fuel only so that's what I got. I forgot to tighten my distributor hold down tab so the timing was all over the place unknown to me. I was on about 4 hours sleep so mistakes happen. I pulled off on one exit and it died and didn't want to start back up. When I took off it was detonating bad. Stopped to eat and went out and set the timing and tightened the bolt. Seemed fine the rest of the way in but I didn't push it too hard on I-44 and 75MPH. I kept it at 65 because my temp sensor is not reading right. The distributor was advanced like crazy. I think I'm going to sleep for a couple days 🙂
other than the minor, glad it made it out and back!count it as a major victory!
