Headlight issue
ELCAM
1,124
1,270
That new switch is just a turd, made in the last 5 minutes of the shift on a Friday before a 3 day weekend turd.
Baker7888
665
115
Maine
Lmao, ok well fingers crossed the one coming is better. I ordered a turn signal switch too as this one is broken
Baker7888
665
115
Maine
So does the same lever on the column control the turn signals and the dimmer?
9,193
15,421
Here's a basic column break down.
Baker7888
665
115
Maine
Thanks for this. So my car has a non tilt/non cruise column. The turn signal lever that sticks out of the side of the column was broken off before i bought the car. I think it looks like (attached pic) Does this lever also toggle the dimmer switch? I cannot tell by the diagram.
9,193
15,421
The lever attaches to the mechanical pivot that besides activates the the turn signal switch pushes a rod downward to depress the dimmer switch itself which is mounted down at the same location of the ignition switch.
Baker7888
665
115
Maine
Okay thanks. I ordered the above lever and hope its the right one
Baker7888
665
115
Maine
Ok if anyone can answer this …. See pic. The “mechanical pivot” as pagrunt put it is broken. I was able to get the little piece of lever out of it. I dont even know where to begin to think where i’d find this part… any thoughts?
Sucks cause i was trying to figure out above how this all goes together. I ended up thinking it was part of the signal switch. Which it is not. So i ordered a signal switch, waited 5 days, it’s here now, to find out. Just kind of a bummer. Didnt want to dig the column all apart until the parts got here. I dont think the signal switch or the dimmer switch is bad so those’ll probably just get returned .. oh well..
ELCAM
1,124
1,270
Does it have a pin or a hollow bolt holding it in the column?
Baker7888
665
115
Maine
It has a hollow sleeve bolt holding in. The shaft for the dimmer goes thru this bolt
