Help Please .. Step by Step Console swap??
I'm planing on replacing my whole Columb as well.
send me your email i got a diagram from evan85 a while back i can mail it to you i cant post it b/c its a pdf i also got some picks from tobyp with measurements also
^^^The mount that sits farthest to the rear.
^^^The middle mount.
^^^The front mount.
The hole that's drilled for the shifter cable is about 4-5 inches forward and about 3-4 inches to the left of the front mount on the transmission hump.
I'd suggest riveting down the rear mount fist and mock up the two forward mounts using the mounting holes in the console itself before you permanently weld them to the floor.
YGspider said:
I'm about to swap out my Bench seat and Tree Shift Coloumb for a 3 speed Console and buckets as well as a new columb with no tree shift whats all the steps can anyone make a detailed acount of what they did....
Thanks
Justin
Justin,
If you have a split bench seat you will not need to add additional seat brackets, the brackets that are in the floor are all you need to mount the seats to the floor. If it is a straight bench you will need to cut the brackets from the donor or order some aftermarket ones from gbodyparts.com.
After you get your seats figured out work on the console. There was a post that had pictures from my car when I put my console in. Those measurements you can count on. Plus since you have a console car there you can refer to those same measurements and install the brackets accordingly. I spot welded mine. THere is a dimple in the floor where you will drill your hole for your shift cable, remove the cable from the donor and put it in your car.
You will hook up your linkage from your column shifter the same way to your transmission. This will allow the operation of the reverse lights. In all honesty, I cut my column shifter nub, filled with polyester filler, sanded it and you cannot even tell a difference, and I saved time and money. You will need the shifter bracket from your old car. If you use a th350 or a 2004r they are a different bracket.
I did your exact swap into a power bucket seat conversion with hurst shifters and a 4 speed trans. Just search some of my posts and you can see the way I did it.
