Meh, I've been down the road of "stand alone aftermarket systems" and won't do it again. I used Accel's system for my LT1 swap years ago now can't get parts or support for it. I see a lot of people trying to justify spending $1,000 on the Holley system but in reality you can't beat the factory hardware for cost, reliability and sourcing parts. I've done a 3 now using a factory ECM and harness for $545 or less. You can also buy used HP tuner packages quite reasonably ($500 or less). Next step for me is likely to learn the software.
1) Junk yard GM harness and ECM $45
2) Learn how to make your own harness - FREE
3) Base tune from local speedshop - $250
4) (Optional) Dyno tune after everything is buttoned up $250
If I was doing just an NA-LS swap, I’d stick with the OEM harness for sure. Rewire and run it.
But I want boost, Flexfuel and at least 600 whp out of mine.
You can’t ignore all the gauges that the Terminator X replaces as well. Wether it be analog or digital gauges, I’d need to spend hundreds of dollars to monitor the car to ensure I didn’t hurt it.
