Hood Hinges update
The OE set-up is used but w/o the spiral wound hood spring is how i understand it. The spiral wound spring is removed & in it's place is a gas strut.
*EDIT* (with the appropriate gas strut anchor pins for each end)
Picked up a set of them today at the local yard for $10. Figured it would be a better idea instead of cutting up my originals. Now that I understand what I need to use I'll drill out the rivets tomorrow and get them in the blast cabinet.
My plan was to get the hood back on over the weekend but my wife had a little "mishap" in the house while I was at the yard this morning. She tripped going down the basement stairs and put a small hairline fracture in her right femur. She was VERY lucky she didnt break her neck. Needless to say shes going to need a little help around the house for a while.
From the looks of it the 317 hinge worked in 10 different cars which would be a good thing. It will save some time figuring out where to mount the shock.
The AMD cowl hood doesnt fit right on my wagon. The edge of the scoop will hit the windshield. Maybe it was designed with coupes in mind. Kind of a pain in the neck. Should have caught it when it was being put on in the bodyshop.
My plan is to try a set of shocks. Another thing to figure out. LOL
Thanks for taking the time to look that up !!
haven't read thru all 5 pages of it, but if hitting the windshield is a problem (which it obviously is) why not convert to a front tilt hood? (not a front clip tilt)
Reactions: 64nailhead
Not something I would even consider for countless reasons. The main one is the cars 98% finished.
If I am reading and understanding correctly, I can use my existing monte carlo hinges, sans springs, and in place use a gas strut? I do not weld, but I "got-a-guy" down the road from me who does amazing work, so if I need something welded up not a problem. Only thing I am missing is the shock, any recommendations for a fiberglass hood?
I've had stock hinges with steel hood, fabbed shock mounts for fiberglass hood, flip forward buick hood mechanism, and several functional modifications to the current setup posted above that I first fabbed up in 2010.
Nothing is simpler than a hinge that simply pivots at one spot like the factory hinges. Tweaking one would have been a pre-teenage skill for me. Mods to convert to strut can be just bolt on. If you're skeered, stick to simple.
I haven't patented my current hood system & have explained it hundreds of times to people thinking about building such a thing. Have seen one kinda similar (slow as f***) on a black vette on Lokar car show, but never seen anything else remotely as complex. Anybody wanting to make their own is welcome to copy it and more than welcome to improve on it.. Always room for improvement.
Next will be my bedcover mechanism that 4 hinges will slide open in almost a straight up motion, going back enough to clear my rear visor, but not so far back as to look stupid. will need to be solid enough to drive on highway almost 3 feet up in the air on a level plane to allow small drift trike motorcycle ( or wife's stuff) to fit underneath. Was close to being initially done designing before having to work 2 jobs over 70 hrs a week lately. Hopefully can get back to soon next year,
Thanks for all the input folks. Not into any custom stuff. Just going with the gas shocks like mellelky used. Im sure I'll have to use a shorter shock due to the difference in the hood I have compared to the factory flat hood but it shouldnt be a big deal. I hope. LOL
