hooked up
1.6719 60...4.9636..330 and 7.7563 1/8 @88.18
the reason i'am a little scared is i burned a hole in #7 in my 350
i think maybe the fuel pressure could of been the problem, i only used 75 off the line and hit a 100 in third gear i was able to make two passes before it blew a hole in my piston
so i'am going to put a fuel pressure shut off before i use it again, also i didn't back off my timing because they said a 100 shot wouldn't be enough to hurt the motor
the engine is solid less than a thousand miles on it ...the bottom is a eagle forged stroker with h-beam forged rods and forged srp 11.0 to 1 pistons so it should work but you can bet that i'll lower the timing this time!!!
