HOW MANY VOLTS???
TURNA
Rocket Powered Basset Hound
Jul 24, 2009
10,941
19,992
Socialist NY
How many volts go the the fuel tank sender?
My gauge stopped working and I am getting 8.51 volts at the pigtail pink wire coming off the taillight harness.
Should it be a full 12 volts?
Thanks
TURNA
Jul 24, 2009
10,941
19,992
Socialist NY
Not the gauge itself the pink wire that comes out of the tail light harness
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
the pink wire goes to the gauge, my pink wire had issues so I ran a new wire right to the guage. The original pink wire goes to the harness on the left side of the fuse box. The sender is 0 - 90 ohms 0 is empty
TURNA
Jul 24, 2009
10,941
19,992
Socialist NY
TURNA
Jul 24, 2009
10,941
19,992
Socialist NY
OOOOOOOOOOOOOFA!!!!!!!!!!
hoffa65
319
416
Atlanta GA
depends on the gauge looks like it might drop the voltage some, I can check on the SS after work tonight
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
I posted that diagram and it disappeared, maybe I don't have the security clearance you have....:popcorn:
the symbol for a resistor (ohm) is in the fuel senders
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
one other thing about the pink wire, at the connector at the left rear of the trunk compartment that braided wire is an aluminum wire from the connector in the trunk to the connector at the left of the fuse box. The aluminum wire corrodes and that could be your problem
  • Informative
