How to change ignition switch?
mheath717
413
19
Florida
Well tomorrow I plan on changing out my ignition switch. I picked one up today for nine bucks, but I have been told its hard to install. What all do I have to do to change it out? I have heard that I have to drop the steering column, and could possibly mess a lot of stuff up. The problem I am having is that when I turn my key, my car won't start. It has been a problem for about the last six months. I drive the car everyday. It used to only do it every once in a while. It is starting to get more, and more common. I would turn the key, and nothing... Try it a couple more times, and then it would fire up. The other day, I had to turn the key like 20 times to get it to start up. Then it did fine for a few days, and now I am not starting at all. I don't really want to be stranded anywhere, so I wana get it swapped out.
Over the past weeks I have replaced the key cylinder, positive battery cable, negative cable, and the starter itself. Figured I would do the actual switch next.
So what do I have to do to swap it out?
20,419
you have to drop the steering column, then disconnect the wiring and on the other side there is a 8 mm bolt near the front and then there is another at the back to remove the high beam switch. When the switch is removed then there is a philips head countersunk screw to remove and that's it..
I think I have it right, I changed mine a few months ago....if you have a tilt steering the joint for the rod may be broken....
megaladon6
4,006
15
Danbury, CT
you shouldn't have to drop the column, not if the key works. pull the steering wheel, then turn the key. IIRC that exposes the bolt. remove that and the cylinder comes right out.
mheath717
413
19
Florida
I don't need to change the cylinder... The actual column switch is what Im after here...
RockSS
276
2
Enfield Ct
That sounds good yes check the rod goin to switch hate to see you go thru all the work and still have a prob.
mheath717
413
19
Florida
Well I do have tilt column so I will definately take a look at that rod. But do you think the ignition is even my problem? I just went out to my car and tapped on the switch a few times, and wiggled things around. Then after turning the key twice, it fired up. Its like it works when it wants to. Makes me thing its an electrical problem.
20,419
the switch is easy to change and inexpensive so why not change it and then you know it's good....one thing I forgot to add is make sure the switch is adjusted properly. It has slots so it it can slide on it's mounting bolts so before you tighten it down make sure your key will operate the switch properly for start and auxiliary.
mheath717
413
19
Florida
So to drop the column all I do is take off that little plate under it? The one with a vent in the middle of it? I looked lasnyt in the dark but thats all I saw to be holding it up.
RockSS
276
2
Enfield Ct
Ok this might be way off but what about the neutral saftey switch ... just real quick the next time you turn the key and noting happends hold it and wiggle the column shroud I know the bushings in the rods comming up from transmission wear out mine did haven't changed them yet I just made a slight adj.
20,419
yeas that panel has to come off, there is 4 fasteners, one in each corner. You don't have to do anything with the vent, that just stays attached to the panel and slides out of the hose. There is two 5/8 bolts that secure the column in place that you'll see with the panel removed.
*edit* rock made a good suggestion, he could be right
