Assuming you have a Buick V6 you need SBC frame mounts, engine mounts, all of the accessories and pulleys, fan set up for SBC a non computer controlled carb and distributor, V8 radiator and shroud, new battery cables
Whelp, there's a few answers to that question, and what rabbit hole we jump down depends on what you're doing with the car.I may take you up on that, we'd have to find a way to ship the Engine. But first I will pose a question the group or for those who have done a 350 conversion on these V6 option cars. What all am I going to need IE; Parts to make this conversion happen? off the top of my head I know Headers, Muffler and pipes, possibly a Torque Converter on the Trans. . . . Fill in blank. . . .
I saw that sticker on a late model something last week...was being driven by a female.....she drove like she was in a hurry to get somewhereMore doors for more wh*res!
The wagons come in 2nd place to the coupe enthusiast 😄
That’s the harsh reality.
The enthusiast come in the back of the wagon..... err..... nevermind.The coupe come in 2nd place to the wagon enthusiast ....
Just when I was getting started on the Sanding and Primer on the body (slowly due to weather) Today earlier I had the Malibu towed to Mosteller Auto Repair again. The Engine was idling erratic and seemed to not be getting oil. Checking the dip stick I found a grainy substance. Decided to have the car towed to find the problem I couldn't solve. But the Mechanic did. He said the Barring is about to give. Will need a new engine. I was going to either re-build or replace the motor anyway. But this puts that ahead of everything else I wanted to get done over the summer.
I need options. Mechanic will look into getting me a motor as cheaply as possible either the 229 or 350 which ever is cheapest. I was looking at few 350 Engine video's on Youtube, definitely considering that swap if the motor is cheap enough. There's just the other minor bits that will be needed to get that swap out complete.
So what should I do on a $1000.00 budget,
- Get a Cheap Junkyard Engine direct vin replacement or 350?
- Buy a Rebuild kit if there is one for the K 229 3.8L
- Other
I was wanting to wait for the Engine rebuild/Swap whatever I decided to do later, many more things this car needs. Now I have to jump on rebuilding/swap of the engine earlier than expected as luck would have it. Your feedback here is most appreciated.
Not quite, the fuel line is on the same side for chevy 229 but the pump is mounted upside down compared to SBC and the motor mounts are mounted further back in the frame on the 229.Isn't the 3.8 chebby V6 like the 3.8 Buick to 350 Buick, a direct swap? Other than V6 only things like manifolds and distributor, the mounts, fuel hook and accessories all swap over, do they not? The only issue I can see if the trans is a TH200 or depending on how radical he goes, a TH250(C). The latter will last fine behind a 305 or mild 350. As we know, the TH200 sucks and nothing should be done to it, other than removing it.
