How quickly, well this is a project car, thus I don't need it right away, but having something happen now wouldn't hurt either.A 6cyl to V8 swap will eat up a lot of a 1K budget.
Is that 1K for everything? Just for the motor? Just for the labor?
How quickly do you need it turned around & driveable?
Before the bearing failure, how did the car run/what was the state of mechanical reliability?
I was able to drive this car for about two and a half weeks before this started, everything seemed fine at first, highest I had the car go was 55 mph while monitoring any fuel, oil, water, trans leaks which there where none. Hell even took my mother out shopping in the car and she loved the smooth ride it provided.
I couldn't gauge mechanical reliability, I don't know. Only thing I do know is these V6's are supposed to be bullet proof or hold their own really well as I am told.
1k is the budget I have right now, and from the looks of things I am going to have to go back to Ramen Noodle dinners for at least another month and half. Mosteller Auto Repair has not yet contacted me about any other engines they could find or labor cost and since I didn't hear from them today. It's likely it won't be until after the holiday that I would hear from them. Even then a used engine wouldn't be worth the money I am about to put out for installation. If they can't find anything I am just going to have the car towed back, I proceed with the body work, rust clean up and paint as I planned for my Summer. Save as I initially planned for an Engine Rebuild/ or New block.
For the money I have to spend on installation which I assume will be costly, I am to the point now that it probably would be best to get a new 229 block, https://www.jegs.com/i/ATK-Engines/059/DB30/10002/-1, Shipping from JEG's at least is free thus cutting the cost of the block down a bit. I would then later on put on a Turbo and other new accessories/parts later. putting in a 305-350 is just starting to seem like a pipe dream as it would be alittle more complicated and more parts than I can afford to handle. I am now convinced it's better just to get this new block that would make things easier, more compatible, and cost efficient to do plus have something low miles to start from.
I want to give you all who have shared your comments on this post a big thanks . Information here is very valuable to my determination on what's to do with this situation. Some times I just need a good reality check.
