Identifying LS Engine
565bbchevy
565bbchevy
7,170
Michigan
So what do I need to look for to find out what exactly this LS engine came from that is transplanted in my 86' Monte
It appears to be a truck engine.
motorheadmike
motorheadmike
4,752
Ottawa, Ontario Canada
D585 coils, earlier PCM, hmm... what are the 3 digits on the heads (PS front)?
Reactions: Injectedcutty
79MaliCrazz
79MaliCrazz
574
Lake Wylie,SC
I heard so dont quote me to truly know what you have the oil pan needs to come off and its stamped on the first connecting rod or cylinder 1 connecting rod.
Reactions: fleming442
O
oldsmobile joe
1,198
mpls
doesn't look to have been modified. with that being said, check the head numbers as mentioned above. this should get you close.
the displacement is cast into the back of the block. 4.8l and 5.3l engines shared the same block, different stokes. iirc, 4.8l pistons were flat and 5.3l pistons were dished. a bore scope camera, or a sharp eye will help you here.
6.0l engines had their own blocks.
  • Informative
pontiacgp
pontiacgp
Canadian Prime Minister
Mar 31, 2006
26,779
Kitchener, Ontario
it looks like a vortec to me, the LS doesn't sit so high and the serpentine set up is the same as I have on my SBC. As far as I know that serpentine set up does not fit on an LS engine
565bbchevy
565bbchevy
7,170
Michigan
I don't know what the differences are between the 2 but the plastic cover says Vortec and the oil pan has this number on it.I don't see any numbers on the heads near the power steering.
565bbchevy
565bbchevy
7,170
Michigan
pontiacgp
pontiacgp
Mar 31, 2006
26,779
Kitchener, Ontario
In the description "OEM 99-02 Silverado Sierra Tahoe Yukon Vortec Engine Cover V8 Assembly. ". I think he stuck the LSX for more hits and if you had an LSX you'd know it..
  • Optimistic
Reactions: 565bbchevy
