I cannot remove the nut that fastens the idler to the center link, the stud started spinning with the nut after a turn or two. I tried vice grips, tried c-clamping the connection point to pressure the stud. No luck. I tried side loading the stud by grabbing the idler and pressing up/down hoping to hold the stud still.
Suggestions? Is the stud designed to rotate?
Doesn't look like there's room to use 2 jam nuts...
