Interior plastic restore. Step by step
HAFROD
HAFROD
2,179
Claremore, OKLAHOMA
I posted this in my Salon build thread but thought I would post it here. Hopefully end up a sticky. I want to say that this is how I do it. There may be other ways but I got awesome results and pretty cheap. With my aero Salon, I did not have an option to buy new panels. Finding good used ones are non existent. Anyway on to step one. I used a portable sandblaster from Tractor Supply around $90. Harbor Freight has a gun that has a hopper on top you put the sand in for around $20 and I'm sure it would work too. I used medium coal slag media. I'm sure just about anything will work. After blasting there were craters and gouges that were left from deeper sun damage. If you end up with an area that blew through, I'd recommend the chrome backed tape used on ducts. That stuff is sticky. You could use a 2 part epoxy also. After taping the back side of the hole, fill it with epoxy or putty. Use a glazing putty and hardner and spread it over the deep areas. I sanded it with 120 grit dry on a medium density foam block. If you don't block it, it will be visible. I wiped it down with wax and grease remover. I then tach ragged it. I shot on a pretty good coat of Dupli Color bed liner in an aerosol can. I let it flash off and shot a second wet coat on. This stuff takes hours to dry so my suggestion is to wait till the next day. I then used a piece of 320 grit dry and lightly rubbed down the texture. Just enough to start flattening it off. This makes it look like the factory grain. Then wipe it, tach it, and spray on your SEM vinyl and plastic interior paint. I don't have any before pics only what I started with today. I had previously shot on roll on bed liner hoping it would fill the low areas which it did NOT do.
salonplasticrepair.jpg salonplastic2.jpg salonplastic3.jpg salonplastic6.jpg salonplastic4.jpg salonplastic5.jpg
Injectedcutty
Injectedcutty
5,168
Louisville, KY
I really like the idea of using the bed liner aerosol, then scuffing it down. It gives the plastic the factory "grain" appearance! Well done on that idea sir!
Hopefully one of our fine moderators will convert the thread over to a sticky as you suggested. That way everybody can see the process.
Longroof79
Longroof79
Rocket Powered Basset Hound
Oct 14, 2008
10,662
Gainesville, Fl
That looks good, man. A friend of mine suggested using walnut shells to blast plastic interior parts...probably not as aggressive as other types of media.
Btw, I have tried the SEM texture coating on my tailgate panel,. It came out pretty good. I also had to fill some gouges and pock marks.
Just like in your case, tailgate inner panels cannot be found for love or money.
Using the bed liner is a great idea.
M
mobileaudio25
518
columbus, ohio
I might add that SEM makes a texture coating for this. I have not tried it
I used the SEM texture coating .... almost $30 per can works great but it will not fill any deep gouges, cracks or severe sun damage.
Longroof79
Longroof79
Oct 14, 2008
10,662
Gainesville, Fl
The texture coating that I used came in an aerosol can. It will not fill cracks and gouges, that's where you need a surface filler/ putty.
mr evil
mr evil
Moderator
Moderator
Aug 4, 2009
842
Sooke, BC, Canada
Stickied...
HAFROD, would it be ok with you if this thread is used as a repository for others methods, tips and trick as well?
Edit, so there is a sticky for panel dying already.....I'll leave it up to GP as to whether we need a second with similar info.....
Perhaps this thread could be a repair/dye how to?
Thread starter Similar threads Forum Replies Date
T Malibu interior New Users 7
W Question about this electrical relay Electrical / Ignition / Starting 2
A interior color rpo Interior 8
C B pillar interior trim interchange? Body / Trim / Paint / Glass 6
C Interior interchange General Discussion 5
Dayzedandkonfuzed What do you use to clean your interior? Interior 3
86sbcmonte MONTE CARLO Interior color code General Discussion 3
P Wagon Rear Interior Panels w/custom speakers G-Body Parts For Sale / Trade 5
stevenc8337 SS interior in a wagon Interior 10
B 1979 Grand Am Interior Parts Needed Pontiac Grand Prix/Grand Am/LeMans/Bonneville 21
81_El_Homewrecker Interior Drone/Sound Deadening Interior 33
Daca214 Thoughts on interior panels satin vs gloss General Discussion 14
Cla66640 Needing Interior parts General Discussion 6
C Searching for a couple interior pieces El Camino G-Body Parts For Sale / Trade 0
jimsmonte80 1978-1988 G-Body upper rear quarter panel interior trim seal Interior 0
MikeBlasey PONTIAC wagon interior Wagons! 6
565bbchevy Interior Picture Of Roof Bracing General Discussion 5
QS442 Claret Interior paint code Interior 11
565bbchevy Ostrich interior with Gator center console. General Discussion 2
Firetruck1 Reproduction Malibu Wagon Interior Parts Interest General Discussion 17
B Interior time Interior 1
80oldscutlass New wheels and updates to interior Oldsmobile Cutlass / 442 / Hurst/Olds 2
GP403 Interior mold and a wtf Interior 9
motorheadmike [Not Mine] NOS Interior & Exterior Trim Oldsmobile Cutlass / 442 / Hurst/Olds 5
T Interior Paint code 62D Interior 3
Hubb79 Chalky interior panels Interior 0
Jjjem interior light/instrument cluster lights stop working Interior 0
Hubb79 Interior dye G-Body Build Threads 14
Hubb79 Interior paint G-Body Build Threads 8
N Interior pieces General Discussion 7
P Green Interior (81'+) Pontiac Grand Prix/Grand Am/LeMans/Bonneville 9
wskirvin CUTLASS Another interior thread Interior 5
O Acrylic/plastic LS Non-G Projects 6
Jmac I'm trying to find these plastic rear glass molding stops there is ( 3 ) of them Oldsmobile Cutlass / 442 / Hurst/Olds 7
D Plastic coupler for power seat motor Interior 9
Stupidquestionspro HELP Exploded plastic power seat Interior 0
Kennyjoe28 Got an 83 regal limited, trying to restore! Buick Regal / T-Type / Grand National / GNX 4
Similar threads
