Hello everyone.
So I swapped my intake and carb last week (first time). I finally got it running, but not well. It's hard to keep running and it back fires at half throttle also I'm seeing some smoke out the valve covers. It ran good before the swap and only smoked for a second on start ups out the tail pipe. The idle screw & mixture screws don't seem to have much of an effect when turned. On a cold start it will run for about 20-30 seconds and die, then it's hard to get running again.
It's 79 Monte 267 SBC. I swapped the stock 2 barrel/intake for a edelbrock performer and holly 4160 600cfm vac secondarys and electric choke. I set the timing at 12 degrees and made sure the firing order was correct.
The carb is used and might need a rebuild, I want to rule anything else out first. I replaced the accelerator pump dia. and fuel bowl gaskets. I cleaned the bowls, needle & seats up and sprayed some passages out. Also removed jets and made sure they were clear. I've been trying to adjust the choke now.
I set timing while idle was a little high but that was I only time I could get it to stay running. So timing might be off a little. I used a vacuum gauge and it read about 21in. But once again the idle was a little high, might not be correct.
Vacuums: I have the brake booster plugged into the intake, Trans vac is on the front base port, vac advance is on the timed port by metering block, pcv is on the other big port on left base. Missing something?
I'm thinking:
1. Vacuum leak (intake)
2. Choke adjustment
3. Timing not correct
4. ?
Please help lol
I'm thinking:
2. Choke adjustment
4. ?
Please help lol
