**add this to the first page
$30k+ on this build.
spreadsheet
https://filehost.net/0c545f289d2753fa
http://s000.tinyupload.com/index.php?file_id=13305271982846616967
Week To Wicked
1987 Monte Carlo SS
Parts Group Manufacturer Part # Price @ Jegs.Com
Under The Hood
Engine ATK Engines SBC - 383ci - 500 HP HP55 $5,980.99
EFI - Throttle Body FITech EFI-4 600HP 30001 $925.00
EFI - Fuel System FITech EFI Fuel Command Center 2.0 40004 $395.00
Headers N/A $0.00
*included in exhaust kit
Distributor Jegs SR-III RTR Pro-Series 555-40520 $205.97
Coil Jegs High Output Ignition Coil 555-40155 $31.49
Dress Up Kit Jegs Valve Covers, Trans Pan, Air Cleaner 555-501101K $354.95
Alternator N/A $0.00
Radiator Champion Aluminum 26" 2-Core EC162 $175.99
Radatior - Install Kit Champion Shroud, Fans, Fan Controller FS162K $313.96
Battery Optima 12V 75/25 - CCA 720 9022-091 $232.99
Serpentine System All American Billet SBC w/ PS & A/C FDS-SBC-501 $2,495.00
Reservoir Canton Power Steering Rervoir N/A $0.00
Steering Unisteer Rack & Pinion Kit 8012400-01 $1,620.00
Intake Manifold Jegs N/A $0.00
Transmission
Transmission Jegs 4L60E L31-R Small Block 555-603015 $1,499.99
Transmission Controller FAST EZ-TCU GM Overdrive 30282-KIT $636.99
Converter N/A $0.00
Driveshaft QA1 REV Series Carbon Fiber JJC-AA0310 $955.99
Crossmember N/A $0.00
Suspension
Suspension QA1 Sway Bars, Coil Shocks, Trailing
Arms, Control Arms, Braces,
Ball Joints, Tie Rod Adjusters,
and bearing kits. HK03-GMG1 $3,442.99
Brakes
Front Brakes Baer 13" Rotors, Spindles, Calipers, and lines 4301367B $2,845.00
Rear Breakes Baer 13" Rotors, Spindles, Calipers, and lines 4302358R $2,445.00
Master Cylinder Baer Remaster Master Cylinder Kit Application Specific $471.99
Rear End
Rear End Currie Housing, Axles, Third Memer CE-GMG7887X $3,286.35 *not on Jegs
Wheels/Tires
Wheels Jegs Old School Wheel 17x7 555-681634 $456.80
Tires Mickey Thompson Street Comp Radial 245/45R17 6273 $494.00
Exhaust
Exhaust Jegs 2.5" Exhaust Kit, Painted Headers,
and double hump crossmember 555-30060K1 $494.97
$29,761.41
not counting the dozens of parts that are needed to finish a build that weren't shown.
