HIDs ara a PITA to troubleshoot! Is it the ballast? Is it the bulb? Aww, hell, it's both!!
LEDs are self contained.
Oh yeah, make sure you install the LED flashers too, or they'll likely not work.
[/QUOTE
If I recall from Digi tails, back when they were called Spaghetti Engineering. Alot of parts stores are carrying them now.Where did you get the led flasher from?
it's easy with a spare ballast to plug in to see if it is the ballast or bulb, most of the problems with hid is the connections are not protected and corrode.
