Lets see those air cleaners!
2x MCSS air cleaners, snorkels and underhood scoops to make my own dual setup. Fairly inexpensive and I wonder why I didn't do it sooner ??
Pro- more air and looks factory
Con - I couldn't fit this setup when I had a holley
Got one of these from a Camaro that I was going to install, but the drivers side snorkel interferes with the AC lines. Is this one off a Camaro and what did you have to do to clear the AC lines. I'm thinking about cutting the snorkel off an relocating it so that it'll clear. Your installation looks great
Frank
Hi Paul,
I might have asked you this once before. Did you need to use a spacer between the carb and air filter to help make the seal? If so, what size spacer did you use?
It was a 69-72 Camaro Air Cleaner it has a 2 inch spacer under it. Got a kit off the internet you need a Chevelle breather elbow pipe and the Chevelle breather hose because it is a different size on each end.
Reactions: theoldsone
Thanks again for the info, Paul.
Reactions: tc1959
Thanks for the info Axisg, now all I need to do is find the missing parts for a reasonable price.
Here's my setup so far. It's a 3rd gen camaro (84 I think) air filter box that I now need to connect to the firewall
Reactions: SUBLIME80BU
This is one I want to go with! Looks bad *ss, and should give the engine better performance than the one I currently have.
im starting to wish i would of went bigger! theres no way i could trick the old lady into a LS swap she already scoffed at the motor so she'd know! I dont even say malibu in the house anymore!
I can't hint at the word Cutlass or anything close to!
