My wife is not too keen on that.. so no comment.
Understood !
Nice setup. The tin work behind the back seat... can you elaborate?Here's my setup, set it up over the rear axle.View attachment 155280
The one thing I learned from my crash was if you are using an electric fuel pump, only use a plastic strap to hold the battery in. I don't care what the track safety guy tells you, in rollover, you WANT the battery to be thrown out of the car. My motor and fuel pump were shut off in the first of 8 or so rolls. With a steel strap holding the battery in, fuel could have sprayed everywhere before I would able to shut the pump off.
I put a Frod inertia switch in my fuel system design. It's mounting is kind of a pain because it's a little too sensitive, but it's also comforting to know it's easily tripped.
