Let's see your battery trunk relocation setup
Got to thinking about this and although I agree you can't have a projectile flying around to injure (kill) a spectator. I think a good solution would be an impact - rollover switch which would shut things down immediately and I plan on looking into it. My Sonoma's cut off switch can be activated from outside and inside the cab but that doesn't do any good if your not conscious to activate it. Food for though.
The hood or Trunk lid will keep the battery from potentially killing anybody. My battery was 150 ft BEHIND my car, so the car itself would have killed many more potential spectators that where seated on the outside of a corner, for some reason. A battery isn't like a tire or a hood. its only going to go 20 feet or so from where it comes out, if it comes out and they don't really bounce too high.
I'm not saying don't secure the battery, I'm just saying the mounting doesn't have to withstand 5G's and definitely not 20G's.
So, when is the full story, UNGN?
I'll make a video of the crash at some point. but basically the car was running too good and the course I was running on I didn't have memorized and I came up on the only corner (blind left, over a hill) on the course where the left turn sign was at the corner and not 100 feet before the corner.
I tried to make the 90 mph turn @ 117 mph and the car was under steering off the road, so I gave it gas to make the car turn... and it worked and the car magically went back on the road, with a 4 mile straight away ahead... but the rear wheel wells were now full of wet grass (it had rained in the morning) so the back tires kept spinning and the car kept rotating. When I hit full opposite lock on the wheel, I locked the brakes down, but we still nosed into the hillside @ over 100 mph, then launched about 40 feet into the air. The launch is what broke my back, because as the car was heading towards space, I remember thinking "uggh, I think my back is broken".
The first landing impact was on the rear bumper, so it did a forward somersault in the air. It did a couple more end over ends, then rolled 4-6 times.
2-2-l2l-crash-jpg.155347
All of the safety equipment did its job and if anything that car was built too solid and transmitted the impact shock to my back. If the seat brackets had bent a little, it might have reduce the G loading on my back just enough that a vertebrae would have just cracked and not shattered. My son's just cracked, and likely so would mine if I was still 20.
Modern Race cars fly apart for a reason. I nosed into a 10 ft high hillside @ 100 mph and the radiator still holds water. maybe the front end was a little too solid.
that is a unsafe track design to have no barriers to prevent cars to hit a hill that can launch your car.
That's open road racing - Earnhardt's crash didn't look all that bad but !!
Earnhardt refused to wear the HANS device which probably would have saved him in the 180 mph crash....as far a road racing there is an issue with track safety when there is no run off areas and no barriers on a high speed corner. The other issue is the amount of grass where the car ended up which could have easily caught fire
Reactions: JAMCAR223
It was a high speed TDS rally, on public roads. Mine was probably the 12th -15th car to be wrecked in the 8 year history of the event. My wreck was nowhere near the worst.
The Luckiest guy in the world did a 90 mph 360 degree spin in an '05 Ford GT and didn't hit anything.
