limited slip diff.
1,167
2,638
West Virginia
See my post above.
20,397
put one wheel on the ground, get a torque wrench on the wheel in the air and see how many foot pounds it takes to break the wheel free from the one on the ground. I think it should be close to 70 or 80 lbs
if it breaks away too soon it may be the last person who had the car added too much posi additive. The only way to find out is I would dump the rear end and just used rear end oil without additive. If the rear end break away torgue is good after that I would try it and if the rear clutch packs chatter around corners add some posi additive.
UNGN
3,048
3,264
Southlake, TX
Who would be driving an '86 T-type in the snow in 2020?
Is it a complete rust bucket?
6,836
6,749
jlat
250
61
hello people: I'd like to learn something new every day and I'm just a backyard hobbyist but thanks to pontiacgp for his and others help. I never heard of the foot pounds thing. I'd like to try it in the future but I'll be driving it for now. They say the weather here in Mass. might hit 75 by Monday and that's in Nov.. I luv it so I want to take my bike out probably for the last time for this year and drive the car also...
How's the weather in Ontario GP?
IBBY
20,397
we got some warm weather for a few days but we know what is coming and I do not like it... :popcorn:
1,167
2,638
West Virginia
How fast did you go? Was there a lot of tire smoke?
Typically the snow will cool the tires faster than the smoke can be produced...................unless you possess tremendous HP. In this case it would be tire steam.
Scientific or what?
OP, that differential was never designed to do what you are imagining (pull the full weight of the car with one tire having zero traction). At the point that your spring pressure (breakaway torque) is high enough to do what you are imagining you will have made it act much different on dry pavement and you'll be asking what is wrong with it in another post. Having both tires spinning evenly in the snow is mucho fun, but not necessarily the safest thing for an unprepared driver. Getting the correct 'snow tires' is your best bet as there is likely nothing wrong with your LSD. PontiacGP had a good suggestion also, change out the fluid to 'non-limited slip' fluid.
Scientific or what?
Nah. If you get mad enough, you can smoke the tires on a 6.0 Silverado and the headers glow orange.
5spdCab
1,190
1,989
Tukwila, Wa.
For some reason, that comment reminds me of how my step-father used to say that the way you drive a Detroit Diesel is the same as if you just had an argument with your wife and slammed the door on your foot as you were leaving the house.
