Lower ball joint tricks anyone?
85GPLef41 said:
I used a hydraulic press to install them.. you using the large c clamp ball joint tool?
The tool is nice because otherwise you need to pull the whole lower control arm and put it in the press but beware I have seen the cheap ones break.
It sounds to me like you purchased the oversize 1or 2 ball joints. I know when changing the lowers on my car the new ones I bought actually slid into the pocket almost by hand ( they were smooth on the sides ), so I returned them and bought the oversize 1, which had little splines on them. They went in with a little more force but I tack welded them in anyways.
The old trick for stubborn ball joints is a freezer, a torch, and BFH.
2 jacks or a lift and stand are needed and remember to remove the grease fitting from the balljoint. It really helps if you can put the balljoint in the freezer for a couple of hours beforehand
1 jack under the frame to raise the car
Settle it down on 1 jackstand under the lower control arm ( with the ball joint removed and enough tension to hold the spring in place) heat up the socket and LCA area the ball joint sits with the torch until good and hot ( not quite red-hot )
Once the area is good and hot slide the ball joint in place from underneath followed by a solid 4x4 block on your 2nd jack.
Continue to raise this 2nd jack it up until you have lifted the car off the jackstand ( but leave it there for safety ) and lower the jack under the frame so 99% of the cars weight is on the balljoint and 4x4 block.
Take you BFH and hit the LCA around the balljoint area until it settles in place. You will actually hear the sound of the get deeper when the balljoint seats itself. I watched my freinds dad who is a mechanic do this for many many years with a 10lb sledge on a 12" handle, worked every time.
I just replaced my whole front suspension, steering linkage etc. I just made up my mind that instead of struggling for hours trying to press in the lowers and possibly damaging them to take them to a shop i already had the control arms off the car so i just dropped them off. i got the old one removed and new one pressed in for 25$ although the upper ball joints are easy to do for 25$ i asked them if they could also drill out the rivets for the uppers and they agreed, so in my mind I think it was worth it...and no time wasted
pontiacgp said:
I use a kit like this to remove them
My experience with this kit was not a good one. I would take the arm off and have it pressed by a shop!
I have used that exact kit , well not exact my box is red 😉 , for years without issue??????? Maybe it's a Pontiac thing. :mrgreen:
Use it to press'em out with a little BP Blaster and press the new ones right in.
Did a mustang, Tuesday.
I found setting my impact gun about in the middle works best.
It can be done with a 1/2" rachet or breaker bar but the vibration by the impact gun seems to be the trick.
the ball joints just wont settle into the cup straight, so when you apply force, they go in cockeyed and can damage the hole and the joint!
bill said:
No offense, but that kit sucks....useless. Take the arm off and have it pressed by a shop. TRUST ME!
I lost count on how many ball joints I have removed and installed using a kit like that...thanks for letting me know how useless they are.. :roll:
:shock: how much does that cost
this ^^^^
This tool works just fine . "If You can walk and chew gum at the same time" . You can use this or any similar tool. Most of them can be used to do U-joints also. Been there done that for many years.
Who walks anywhere anymore?....lol...well the kit I had sucked, so that my opinion....maybe the kit was bad ?
