LS ECM, fuse box and instrument cluster wiring terminal placement
doood
Amateur Mechanic
Sep 24, 2020
579
791
Hello Guys,
Does anybody want to share pics of where they mounted their LS ECM if inside the cabin? My harness was made by PSI conversions with the intent to mount inside the cabin (under dash or even in the glovebox).
I have 3 components to mount under the dash. The LS1 ECM, a small fuse box with 2 relays and 5 fuses, and a wiring terminal box that communicates with dakota digital instrument cluster via ethernet cable.
I would be happy with suggestions from those who are happy with their ECM mounting inside the cabin. I guess I will be rippping out the old ECM.... maybe I should focus on fitting the LS ECM there...?
Regards,
Mike
Injectedcutty
G body LS mafia
Nov 24, 2014
6,057
22,811
Louisville, KY
Mine is mounted behind the glovebox. I mounted the ECM to a factory bracket I pulled from a Blazer which is custom mounted to a firewall plate.
81cutlass
4,649
13,565
Western MN
I put mine underhood because I used a stock harness and it fit there well, and GM intended it to live under the hood for 300k miles in dusty wet conditions and be fine.
But since your harness is already built to go inside, plus it does look cleaner, I understand.
I can say from 1st hand experience it will NOT fit in the stock PCM location in the kick panel. That location is much to small to fit a LS PCM.
doood
Amateur Mechanic
Sep 24, 2020
579
791
doood
Amateur Mechanic
Sep 24, 2020
579
791
I agree about mounting it under the hood no problem with filth and longevity.... that was the original plan.
doood
Amateur Mechanic
Sep 24, 2020
579
791
Mine is mounted behind the glovebox. I mounted the ECM to a factory bracket I pulled from a Blazer which is custom mounted to a firewall plate. View attachment 171647
Is that a floor mat there? So, it's behind and below the glovebox....? I have some odd heat-only duct work back there; it is taking all the space.
doood
Amateur Mechanic
Sep 24, 2020
579
791
That's the carpet. Yeah I yanked all my climate control years ago and therefore had the room to spare.
maybe I'll put ECM where the ashtray is.
I can' rip out the climate control LOL; not a race car. I've figured I'll either mount it where the ashtray is under the radio (visible) or I will sacrifice the glove box. I figure I can remove the glove box and remove its bucket and turn it into a panel that hides the ECM. I'm going to leave the old wiring in place for now; I can remove it later - unplug and label what I must for now.
doood
Amateur Mechanic
Sep 24, 2020
579
791
I took apart the glove box and there's not enough room even if I gut it, so I guess I'll put it where the ashtray goes after I remove this OBD1 port. maybe I'll paint it blue.
Texas82GP
Just-a-worm
Apr 3, 2015
7,989
18,697
Spring, Texas
Why not put it on the tunnel, as far forward as you can? Otherwise, shorten the harness and put it under the hood.
