Quarantine in the lands of Canada has officially gone on too long.Coming in here to read this dumpster fire is like....
I'm not sure we can let them back into society...
Ive been in Cuba for 3 months now, its even worse.Quarantine in the lands of Canada has officially gone on too long.
Swapped for better weather, rum, skantily clad women and cigars. Make the best of it.Ive been in Cuba for 3 months now, its even worse.
75% power losses on transmission lines? And the heat radiated from transmission lines is what causes fires? And multiplying the usage on an appliance by 2?
My friend that is all absolute nonsense - I suggest you do a little bit of research before saying things like that. No, nothing you said is correct.
Losses from transmission and distribution are typically on the order of <10% total, from generation to consumer. I'd say on heavy load days it may be closer to 15%. If you would like me to write out a sample calculation I'd be happy to do so.
Heat doesn't cause fires - faults and arcing do, neither of which have anything to do with the temperature of the lines themselves.
There is voltage drop and power loss from your meter to the various appliances in your house - that is just physics. To say that something like a 1500W microwave is more accurately using 3000W is insane. I would say phantom losses are on the order of watts, maybe a couple hundred.
I understand that voltage loss is not the same as power loss - I am an electrical engineer. Let me show you a sample calculation. We'll go from transmission, to primary distribution, to secondary. This means from the generator, through long range transmission lines, through the substation transformer, through the road-side distribution lines, to the transformer in front of your house, through the secondary wire, to your meter.Arcing is a more intense form of the process going on inside the lines. Electrical conductivity could be described as small-scale arcing, one molecule to the next. Energy is lost to heat in the process. That was my only point there, probably not well stated.
As you should know, the conductors in use are not superconductors. There are large losses to heat with any practical conductor. Over time the conductor itself is degraded.
Hard figures are difficult to come by. It's not something utilities like to talk about, I suppose. Your figure of 10-15% sounds more like what I've seen utilities specify for voltage loss; I couldn't find anything specified for wattage loss. Voltage loss does not equate with wattage loss. My figure of 75% comes from something I heard about the grid between Grand Coulee and California. I am not an electrical engineer, and cannot vouch for it. I have an old electrical engineering textbook with utility-oriented material in it, but I gave up trying to get a useful calculation out of it. As I recall, some factor was required that I had no access to.
You are correct, the microwave is not using 3000W. The microwave is using 1500W. The other 1500W is "used" between the meter and the microwave. Or so the "rule of thumb" said. I added everything up and multiplied by two, and the result seemed reasonably close to my electric bill. This was long enough ago that I'm having trouble remembering if the "rule of thumb" came with a utility bill or with an appliance, but it was one or the other.
If we accept your "maybe a couple hundred" watts of "phantom losses" for a 1500W appliance, that would be about 13%. But again, that's between the meter and the appliance. Extrapolate that to the distance from Grand Coulee to California, and then within California. Since it's a characteristic of the conductor, it will in some sense multiply with the length of the conductor.
For sure, no problem brotherThat's very good, thank you. From all of that, a reasonable ball park loss between Grand Coulee and the typical consumer's meter box in California might be roughly 25%. But this happens to be the inverse of what I stated (75%). So it's possible that either "my source" had it turned around, or that I myself got it turned around in my own head. Either can and does happen, lol.
The "source" was an installment of the Frontline series on PBS. Those claim to be documentaries, but I've caught them bending facts to suit their purpose, just about routinely. So I did try to do some homework on it, and like I said, got nowhere. And this was a few years ago, long enough that I don't remember when exactly.
I have another question to raise. I'll be back with that, maybe in a couple days.
Oh I'm not doubting that there are plenty of old transmission lines around the country, you're right in saying that some lines built in the first half of the 20th century are still in service today.It would help if I could remember more about that show. They made specific points, but it was long enough ago that I don't trust my memory much. Can't find anything about it on PBS, either. So overall, we're deteriorating into a very murky scenario.
You seem to assume that all transmission lines are fairly new, but I doubt that's the case here. I know it's an issue with PG&E. It was recently revealed that some of their longer, more remote lines date back a long way, like to the early 1900s if I remember correctly. I don't remember when Grand Coulee first connected to California, but I'm doubting those transmission lines have been replaced since, for the same reasons.
But good information is difficult to find. Generation capacity is all anyone seems to want to talk about.
I was saying that the losses are likely worse once you get to distribution (which is also outdated). Again, not that it matters where the losses occur - I was just pointing it out.
