79loserbluebu said:4L80s will fit in G bodies. My buddy that's building a TT 6.0 Monte has a 6L80 in his and that trans is huge.
Actually it depends on the setback of the engine, and hammering of the tunnel.
beeterolds said:
motorholmes said:beeterolds said:
Do you have a part # for the MAP sensor?
beeterolds said:find one off any 4.8 5.3 or 6.0 its the same part
which part # motor mounts are you usingbeeterolds said:It can be done on the SUPER cheap and I mean I have maybe 1500 including engine invested..... I had my friend make me the cheap motor plates.. 1 inch set back of course... you can make them yourself with a little bit of imagination and drilling... and fitting.. and more drilling.. and fitting.. and fitting and swearing!!
1.)Cheap junkyard SBC clam-shells CAR only.. truck shells are too big...(you need to trim about 1 inch off the passenger side to clear the AC mounting bosses on the block tho...
2.)I used the stock flywheel, I ovaled out the converter holes and used the $45 Hughes step bushing to mate the flexplate to the converter...
3.)I used a $40 2000 Z06 Camshaft which isn't a crazy TR 224 grind or other but its NOT $$400! and it should give me a modest bump over the stock stick..
4.)I scored a Cheap Cadillac CTS-V oil pan (However a stock truck pan will suffice) I just didn't feel comfortable.. to each his own tho..
5.)Stock 3 core radiator, with a 20734 Gates Lower hose and a trimmed down upper from a truck... I made my own coolant bypass pipe to give me provisions for the steam line as well as the mech. coolant temp gauge..
6.)Lincoln Mark VIII cooling fan which is 2 speed and flows almost 5000cfm..
7.)The most expensive parts were the intake $215 (my work discount) and the Msd 6010 (found it for $274 online shipped!) DO NOT BUY THE $700 EDELBROCK SETUP!!!! your wasting your money!!!
8.)I used stock truck accessories... use the smaller 105 amp alt... it will provide you with better clearance and what the hell it puts out 40 amps more than the shitty 60 amp GM unit from the 80s...
Also I used a stock cheap power steering pressure hose from a 307 Cutlass, Regal or whatever... it worked perfectly!!!
9.)If your going carb'd the best fuel pump IMO is the 1987 Monte carlo 4.3 pump... use it with a Caddy cts filter which has a built in return line and have the filter near the tank so your not running 60 miles of hose under your car!!! Run a good adjustable regulator, like a holley or Quickfuel... and set the b*st*rd at 6psi or whatever your carb calls for...
10.) Im running a driver side F-body exhaust manifold (clearance for miles!!) pass side is the truck.. i might grab a f-body as well.. I dunno I dont like how close it is to the frame..
11.) Autometer sells a fat brass metric-std adapter for your oil pressure gauge.. Cant remember the # of the top of my head tho...
