I’m continuing to clean up and establish final harness layout. I cut quite a bit out. Slowly things are shaping up. The bundles on the passenger fender well include pcm, relay/fuse box and my junction box. I have two toggles mounted in the junction box that allow manual control of fuel pump and cooling fans if ever needed for redundancy or diagnostics. All connections are spliced and shrink wrapped. The blue painters tape bits you see are just tags with circuit numbers written on them in case need to go back in later. Obviously, all of these bundles will be covered in split loom closer to the end of the project. Next I’ll be moving to the wiring portions that run up the intake and across the firewall.
