I've decided to put a bypass style heater control valve in. This is instead of the straight shut off type. The reason is I can't find any instance where an LT1 engine was installed with anything other than a restriction type valve or a bypass valve. So to be safe I want to continue the coolant flow through the hoses but prevent it from circulating through the core. Here's the valve I'll use.
View attachment 182032View attachment 182033
you are correct, but i put one in anyways. my thought process is the vent pipes off the back of the head will suffice as a coolant bypass. now that valve only works when in the MAX a/c position. i don't have a working a/c yet, so the jury is still out for me.I've decided to put a bypass style heater control valve in. This is instead of the straight shut off type. The reason is I can't find any instance where an LT1 engine was installed with anything other than a restriction type valve or a bypass valve. So to be safe I want to continue the coolant flow through the hoses but prevent it from circulating through the core. Here's the valve I'll use.
i have changed out these springs, but be very carefull, they like to bite. and they bite hard.Closed the hood the other day and heard a loud bang. The hinge spring popped off. Is this easy to put back on or are we looking at a hinge replacement?
yesIs there supposed to be a splash guard on the front fender wells where the upper control are is?
double check your grounds. especially the group ground in the harness that are common on the factory harness.The combo is running good but I still have to iron out a few bugs. I'm getting code 21 TPS voltage high. It's causing qwerky transmission shifting issues. You can see in this vid clip that the voltage on the high end exceeds the max 4.75 that begins the fault zone. An easy adjustment I'll make when I get back at it.
Here's a vid showing the tps voltage going too high
None of the A/G's I've owned had them. Never seen any in the bone yards with them either.Is there supposed to be a splash guard on the front fender wells where the upper control are is?
10-4double check your grounds. especially the group ground in the harness that are common on the factory harness.
i stand corrected. i looked at my gbodies, none of them have it.None of the A/G's I've owned had them. Never seen any in the bone yards with them either.
