Well took it for a drive again this morning and still same thing is happening. What i still find very odd is how its reaching that low idle really fast?
Bowiemontecarlo86 said:Do u have and vac leaks? I would go threw all the hoses and such and check.
TURNA said:The defroster turned on your high idle
sounds like you have an electrical problem
start wiggling wires while the car is running
Lorenzo said:TURNA said:The defroster turned on your high idle
Well i notcied before when i put the AC on Bi Level that also made the car idle high. When its on Vent on economy it idles low
pontiacgp said:Lorenzo said:TURNA said:The defroster turned on your high idle
your carb has a solenoid that increases the idle speed when you turn on your ac to compensate for the drag of the compressor. If you turn on the defrost that turns the ac on.
Turna said:The defroster turned on your high idle
Oh ok good to know i dont have an electrical problem then :lol: Its just i dont get how the problem fixed itself when i was driving that day. Still boggles my mind :?
TURNA said:Turna said:The defroster turned on your high idle
Like I said the defroster turned on your high idle.
But that is not the reason it was bogging.
Somewhere something got stuck, there is a break in a wire or a bad ground.
I would still get under the hood while the car is running and wiggle the wires around. If no changes then hopefully it was a one time thing and something got stuck open or closed.
But if you wiggle the wires around and the problem comes back, then yes you have an electric problem somewhere in the harness.
You may have pinched a wire installing the new carb.
