Fairly certain the purple wire is bat+ and brn/blk is neg- If you only have one wire, it's likely purple. There may be a grn/wht wire, that should be 3rd gear select to the computer. IIRC, purple comes from the battery through the brake pedal. The green/white to the computer goes to ground in third gear. The brown/black wire is the ground switch wire from the computer. This way the converter won't lock until the trans is in at least third gear, but will unlock when the brake is applied. The computer also uses engine temp to decide when to lock the converter by grounding the brn/blk wire. It's pretty smart! :lol:
You could wire the green/white to the brown/black via a switch in the car and leave the purple wire through the brake pedal. This way once the engine is warm, you can flip the switch and the trans will lock the converter itself in third gear. And still disengage when you brake. All these wires should be near the computer in the right kick panel.
