Matching touch up paint - spray can
19,994
When I was a kid I watched my new neighbor across the street paint his entire van with a roller in the driveway.
I have done it more then once to vans
9,226
15,529
I have used https://www.automotivetouchup.com/index.htm
With good results about a 1/2 different times on different cars.
The problem is your paint is old and weathered even if it doesnt look it.
This paint is new.
A shop can match the weathered color.
The trick is to fade the paint into the old paint with something like an overspray
Beside this the smaller amount of paint mixed the greater chance of not being a good/close match. If you want to use a "spray bomb", get maybe a pint or quart with everything needed to spray & get a Preval sprayer (https://preval.com/) then you'll have a better chance of a good match with a formula that you can have remixed when/if you need more.
Neill
114
98
Roanoke ,VA.
PBGBodyFan
788
1,221
Wisconsin
I ended up getting a paint supply place to mix the color code and put it in an aerosol can. Match looks great, did the fillers and mirror today. Tempted to spray the menards $3 paint on the old mirror for fun to see how it looks.
85ss/85gn
292
258
beaver dam,wi
Do it ill like to see the difference in paints
8,242
17,743
Glad you didn't do it with the Menard's crap. It's not even CLOSE! Unless it was meant for an eggshell white car.
