Maybe a dumb oil ?....
RICKDIZZLE
251
218
Ok...here is the question. How many quarts are truly suppose to be run in the 3.8 V6 such as one that came in the Oldsmobile Cutlass in 1985. I run 5 quarts, dip stick says 4 quarts capacity and people are telling me its 4.5 quarts. A buddy of mine advised I could be shortening my engine life due to running at 5 quarts. Tried to google it but cant find a straight answer. Whats the real word on this everyone?
6,836
6,748
Whatever reads full on the dipstick when the engine is cold. reason? So most of the oil drains down to get an accurate reading. Should have it in the owner's manual.
6,836
6,748
Usually you only put 5 quarts in with an oil filter change. 4 normally just draining out of the pan.
lilbowtie
3,460
3,965
Canton Mi
I'd use the manufactures specs.
Oldsmobile Cutlass Supreme Sedan 3.8 V6
as offered for the year 1985 since October 1984 in North America
Make:
Oldsmobile
Model:
Cutlass 5th generation
Submodel:
Optional equipment:
Production/sales period:
October 1984 - October 1985
Modelyears:
1985
Body style:
sedan
Doors:
4
Traction:
RWD (rear-wheel drive)
Engine type:
spark-ignition 4-stroke
Fuel type:
petrol (gasoline)
Cylinders alignment:
V 6
Displacement:
3791 cm3 / 231.4 cui
Horsepower net:
82 kW / 112 PS / 110 hp (SAE net)
Horsepower gross:
Transmission type:
automatic
Number of gears:
According to our sources, oil, coolant and fuel capacity for this version of 1985 Oldsmobile Cutlass Supreme Sedan 3.8 V6 are as follows:
Engine lubricant oil capacity:
4.7 liter / 5 U.S. qt / 4.1 imp. qt
with filter change
Engine coolant capacity:
12.3 liter / 13 U.S. qt / 10.8 imp. qt
Fuel tank capacity:
68 liter / 18 U.S. gal / 14.9 imp. gal
Battery capacity (Ah):
45
airboatgreg
2,870
3,116
Go with the 5 quarts. Actually as I recall it is closer to 4.5 quarts due to the small oil filter. Remember oil provides about 30% of cooling capacity
CaliWagon83
1,933
2,139
Orange County, CA
OK. I'll follow up with my own "dumb oil question." At some point, I'm going to attempt to crank over my 3.8 that's sat for 5 years. My buddy says if you get it to crank over and idle, run it for a while on the old oil (assuming you have enough) THEN drain it and put in new. I thought the best thing to do was to drain the old oil before you start it, and put in fresh.
airboatgreg
2,870
3,116
I can pick either side and argue. If you opt to change oil you should always fill the new oil filter with oil before you put it on. The 3.8l was a bit particular on this. I would crank on old oil as you don't know how it is going to run. Flooding? may have developed a coolant leak internally. Remember oil really doesn't wear out. It just gets contaminated with crud, fuel, coolant, exhaust by pass, etc.
Start it, see how it runs then you are on a clean plate when you change the oil.
Next question is why did you park it?
CaliWagon83
1,933
2,139
Orange County, CA
Long story. Right now, I'm in a townhouse, and I don't have room for a third car. My mom lives by herself, and we recently sold my late dad's car, so she had space for it in her garage. Unfortunately, she lives 400 miles away, so I can't just buzz over to mom's to tinker with it. The longer story is it was the family car for I guess what was essentially our "second home," and lived in Knoxville, TN for most of its life. Since we weren't really using the Knoxville house anymore, my mom decided to lease it out, but we needed to do something with the wagon, and I told my mom I wanted it.
The long-range plan is to get a house down here with space for a third car, and it will be my ongoing weekend project. Right now, my plan is to go back up to my mom's over a long weekend, and try to get it cranked over.
airboatgreg
2,870
3,116
Sounds like a great plan. Good luck. Will you have any issues with the smog stuff living in California?
