Easier than with the engine in but can be done with the engine in without too much difficulty. The upside of the Jeep shaft is that it eliminates the rag joint, thereby tightening up the steering feel and giving more clearance for headers.
where can I get the jeep one then ? have a part number ? ill do it while the motor is out.Easier than with the engine in but can be done with the engine in without too much difficulty. The upside of the Jeep shaft is that it eliminates the rag joint, thereby tightening up the steering feel and giving more clearance for headers.
Check out the link in post number 5 of this thread.....where can I get the jeep one then ? have a part number ? ill do it while the motor is out.
ugh of course its sold out.Check out the link in post number 5 of this thread.....
https://gbodyforum.com/threads/jeep-steering-shaft.61687/
You have to slightly enlarge the groove at the base of the steering column so the pinch bolt will go through.nvmd found the part number on the sold out one and cross referenced it and found another listing thanks !
what kind of modification is required?
ah doesnt sound bad lol considering im building a whole car i guess i can do that lololYou have to slightly enlarge the groove at the base of the steering column so the pinch bolt will go through.
