We may of had them longer up here. It may have been an early year option as well. Yeah, all 3 turbo diesels were comparable power and mileage wise.
Yup but didn’t match truck for truck. Chevy kept showing you had to “upgrade “ to match and didn’t show (at the point I stopped ) the seat had room to recline.Not a whole lot new with the Dodge lately, I've been driving the F-150 for the most part because remote start and heated seats are hard to argue with, but I still take it out a few times a week. We haven't had much snow and rain has washed the salt off the roads for the most part so I haven't felt bad taking it out.
Cold starts haven't been much of an issue, today was the first time I had to cycle the grid heater to help it start and once I did it fired right up.
The horn has started working intermittently so I'm going to need to look into that before long. There are some other items I want to address when I get some time. Emergency brake cables need replaced and the front axle seals are leaking. The axles seals are a PITA and the carrier has to come out to do them. That being the case, I'll probably do the drivers side ball joints at the same time and maybe rotors since the axle shafts have to come out to replace them.
I did a side job a couple weeks ago taking some trees down and we used it as an anchor for a snatch to pull the trees down. It was the only truck heavy enough to not get dragged.
View attachment 212997 View attachment 212998
I saw this video on YouTube the other day, thought it was funny/interesting. The other truck manufacturers must've been pretty worried when these trucks came out. Worried enough to make a video addressing it to their sales force anyways.
Sorry about the front axle seals. Just a heads up, if the axles show a wear grove replaced them. My 98’ had the dealer fix the first one ( inner right side) dumass “tech” didn’t say anything about it and slammed the axle back in. Leaked even worse. Made the dealer eat the cost of redoing it and put a new axle in. At that point had them do both seals and axles. I’m not one to play their games. While your in that deep check the pinion seal and pinion for same wear.
You can get greasable axle u-joints. Not sure on the diesel HD front ends, but you could on the 1/2 ton. FYI: you can do all that in truck, at least on the 1/2ton, and never drain the fluid.
My dually wasn't super happy with the -5* start yesterday, it's about 2* now and I'm going to do it again but this time with the laptop running so I can clean that up a bit.
Truly the most fun part of owning an old diesel.
