Re: My Latest Carburetor (q-jet guys will get a kck out of t
There's a few things to check, as you've probably read, we were mentioning air valve spring tension, starting at 3/4 of a turn from zero is a place to start (worked well for my I-6). When you push down on the flaps, can you watch the secondary hanger raise up? If not, your cam that lifts the hanger may have deteriorated, I noticed that with a few of my parts carbs. Next, is your pull off working correctly? There's a couple different types, some have one pull of diaphram for both choke and secondary, and some have separate ones. If your choke pull off is not working correctly, there is a little tab that prevents the secondary throttle plate from opening (it's a little arm that locks against the little pin on the throttle shaft). I usually omitt this piece, as long as you know better than to wail on your car from start up, it won't harm anything not having it there. Look at these few things, cycle the throttle to see if the secondary plate is actually opening (engine cold you will have to hold that little arm away from the stop pin). Other than that, as long as they aren't corroded closed (seen that too, lol) they should work if all that is in check.
