Mystery knocking
Antonio Briscoe
11
Hello everyone i have a quick question, i just changed my rod and main bearings, torqued everything back to specs,get the engine back together only to reveal that its still knocking if anyone could please help it would be greatly appreciated. Thanks
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
welcome to the forum, if you didn't find a bad bearing you needed to keep checking till you find the source. It could be a wrist pin on a piston
Texas82GP
Just-a-worm
Apr 3, 2015
7,988
18,696
Spring, Texas
Consider getting a mechanic's stethoscope from the auto parts (Lisle is a good brand). It could be really helpful in locating the source of the noise.
MrSony
6,831
6,741
Des Moines, Iowa
Warped flexplates and loose flexplate bolts sound like rod knocks. Does the knock get louder with RPM increase? If it does it's something that rotates with the engine. If it's a constant speed sound, its nothing catastrophic.
Antonio Briscoe
11
Can't be the flexplate, its brand new not really sure what it is but im just about at my breaking point with it
85442/86buick
746
1,118
Perth Country , Ontario
welcome ,
never say can't be its new .
what engine are we talking about ? was there any machine work when installing the new bearings ? was the crank turned under size ?
Dave
Antonio Briscoe
11
And it sounds as if its coming from the front of the engine...somewhere between the timing cover,cylinder 1,or cylinder 2 not really sure tho...
