Speaking of Silver... I'm just imagining your car painted Silver along the bottom, with a Red Stripe separating the black from the silver like Dale Earndhardt's car. Would look pretty sweet! (Just a thought of course!)dirtywhiteboy said:I have a set of iroc wheels for it. I need confirm the offset will work with the b-body spindles. Those spindles are wider than stock and I don't want them to stick out or rub. I am still putting the interior back together, when that is squared away, I will deal with the wheels. I might stick some torque thrusts on it if I can locate some used ones. If I use the z-28 or iroc wheels, they will be blasted and painted a semi stock silver of some sort.
Blake442 said:Actually, it's from when the car spent it's first 25 years in Texas...
Apparently everything is bigger there... including the hail...
