NEW TANK
69hurstolds
8,198
17,600
Hmmm. Not sure if either of those tanks will help. Looks like it's got a hole right in the center top on both of them...…. :p
ItsnotaGN
662
1,142
Colorado
TURNA one thing you might consider on the aftermarket tanks (I used a Spectra in the Monte) is some of them fill fuel like sh*t with the aftermarket necks. It might be worth considering one without the neck attached and having your original fill neck transferred. Then again, I don't know for sure if it's an issue on the Cutlass tank, but the Spectra tank almost always spit back if you tried filling it too fast, something the factory one never did.
84calelky
Nov 20, 2018
70
110
33
The newer Spectra tanks have a vent tube inside tank that runs up to the filler pipe that fixes the fill issue.
  • Informative
TURNA
Rocket Powered Basset Hound
Jul 24, 2009
10,941
19,992
Socialist NY
My luck i will get an old one!!
84calelky
Nov 20, 2018
70
110
33
If you do just drill a hole and add a 3/8 barb fitting in tank by sending unit . then drill a hole and add 3/8 barb to filler pipe . run a 3/8 fuel hose and issue fixed.
you can solder the barbs into hole , just do it before hand and be sure to flush out any metal shavings from tank.
TURNA
Jul 24, 2009
10,941
19,992
Socialist NY
Yep
th
