So I am trying to track down a problem with my car, or at least what I believe to be a problem.
Last year I ran the Cutlass at the strip and ran a best of 13.77 @ 99 MPH with a 2.0 60 ft. That was with a flex fan and an Edelbrock 600 CFM carb. This past weekend I took it out again but swapped on a Holley 750 CFM carb (dual feed, vacuum secondary) and I am now running an electric fan instead of the flex fan. I still only managed a best run of 13.77 but hit 100 MPH and nailed a 1.9 60 ft.
I was racing against a couple friends and their G8 GTs with tune, intake, and headers. I can rape them off the line but they reel me in quick and blow me away at the bottom half of the track pulling 13.2 - 13.3 @ 106 MPH and 2.1 60 ft.
It just seems like my engine falls on its face after 4,000 RPM and I can't figure out why. My car is lighter and has a lower rear end gear ratio then the Gas, yet they pull hard in the upper RPM and my car just basically does not...
This is my setup - 350 .030" over (355) SBC, 14" K&N filter (brand new), Holley 750, Edelbrock Performer intake, Trick Flow Kenny Duttweiller CNC aluminum heads (195cc intake runners, 2.02 intake 1.60 exhaust valves, 64cc chambers), Comp Cams 280H (.480" lift, 230 @ .050" duration) Trick Flow 1.5 ratio roller rockers, Hooker comp long tube headers, 3" duals with flowmasters and turn downs right before the axle. 200-4R trans with TransGo shift kit and stock converter, 7.5" rear with 3.73 gears, 255/45/17 tires.
Is it just me or should I be running better then this with this setup?
