Pontiac, aren't you still technically using the stock position solenoid in that diagram? The part you are trying to bypass. Why not just run the battery wire from the remote solenoid directly to the starter stud, bypassing the stock solenoid all together? Then there would not be a need for the short wire from the batt post to the s terminal.
