If it wasn't for products like this my original 229 would of never made it through the mid '90's.![]()
Stops smoke
- Reduces oil burning
- Viscosity improver
- Coats engine parts
- Quiets noisy engines
Old School, no filing required😆
Thanks, Jeff. I'm hoping for good luck with the rod journals. If they are scored, I'm going to try smoothing them out with some 1'' (or so ) abrasive belts I ordered on e bay. I have never tried this kind of 'heavy duty' hand polishing on crank journals before, so I'm looking forward to it, no matter how old the tech is, and, as referenced here, 'tech' meaning both 'technology', or age of 'tech', (me).we only used to shim the bearings if we were selling the car if we would keep it we would use new bearings good luck on your project Jeff
Stops smoke
I came across an old jeep with an iron duke in it.. the iron duke was just plain noisey.. everything rattled.. Put two of those in and it quieted down nicely.. About an hour later, a guy drove up and said "Ill give ya $2000 for that.." I smiled, held out my hand.. " (I got it for $600, and never was really into Jeeps much). He even commented how well the engine sounded. 🙂
-Gonz
I think pontiacgp may have brought up cam bearings because of the oil path of SBCs. If cam bearings are shot your crank is already being starved. May not be your problem but it's something to consider.New inserts should always be used , with or without the shims, i.m.o. I just do not think 'my 'cam bearings are that worn. It is a factory engine that was never worked on internally, and never run without oil. I don't feel like yanking the engine. Some of us kind of like taking a slower pace on these things, regardless of the ultimate outcome...lol
Thanks , I am just - hoping- they are not.I think pontiacgp may have brought up cam bearings because of the oil path of SBCs. If cam bearings are shot your crank is already being starved. May not be your problem but it's something to consider.
