Olds 307 emissions crap removal
question is will I get more performance and less fuel millage? I want to take mine off because it would clean the engine bay pretty good and it screwed up the paint on one of my valve covers when I tryed to put it in so I had to repaint it. another thing that I would like to add will the engine light come on if I take this stuff off?
Im not sure but I do not believe it has an effect on fuel efficiency or performance at all. Im sure there is someone that has more insight into the pros/cons of removing.
DeltaDevil88 said:
Thanks I did a online search and seems like most come in a hex fitting.......Will those works or is it a round fitting???
A plug is a plug. Doesn't matter what kind of head it has as long as it's 1/4" NPT threading.
I think there's a little performance to be gained and here's why; There are tubes protruding into the exhaust ports in the heads. It's reasonable to assume these would pose a restriction to exhaust flow. To remove these tubes, you have to remove all the AIR crap that screws into the heads. Then you jam a thick Philip head screwdriver into each hole and wiggle it a little. Pull out the screwdriver and you should have a small peice of tube on the end of it. These are the little tubes that are protruding into your exhaust ports. This is why just snipping the big steel tubes going to the heads and crimping them shut is not the best idea.
So I see no way removing all of the AIR crap in this manner couldn't improve power, even if just a little.
Thanks for the input but does someone have something about the engine light issue?
*edit I unplugged the connector going to the pump and the engine light did not turn on when it was running. Can't wait to take all that crap off this weekend
You need to check what the code is first.
well I did mine but not with expected results. It was going pretty good at first I disconneted the emission lines going to the driver side manifold and plugged them with 1/4 inch brass pipe plugs then when I went to do the passenger side they all snapped off in the manifold :/ I don't know what to do now :blam:
DeltaDevil88 said:
What size plugs do I need after removal??? and where can I purchase them at???
Just cut the plugs off like I did and fill them with JB Weld.
I'll stick with the plugs fill with JB seems a lil too ghetto for me lol.
Damn dude you haven't even started on this yet? This shouldn't take more than an hour or so.
Take a look at your engine and you'll see the AIR pump has it's own belt. Just cut it off and you don't need to worry about any of the other belts.
