Olds 403 value?
I am not an Olds guy. What is there down low on the pass side that would puke like that? Either above or below the freeze plug. Oil gallery?
Exactly. Maybe a head gasket? That may allow oil and coolant to mix then shoot it out the side. It is in a totally inaccessible spot. I tried a mirror-on-a-stick even and could not see.
Either way the bearings are probably toast now
True. But bearings and gaskets are a LOT better than a cracked block. I'm not finding a "visible V-8" type image of the 403 anywhere.
Are these oil galleries inboard or outboard? And could a crack pick up coolant? 403's have oil cooler lines? Could be that too.
Olds 455 Oil Cooler Lines
next
View Larger Image
Here is one you can see through
  • Wow
Consoles seem to be unobtanium as well
At least decent ones
Reactions: slow 442
