Bienvenidos. Me fui a Santiago dos veces cuando era joven. Que Lindo y viña del mar tambien. Como dijo estos, hay muchas websites incluyendo rockauto.com que tienes muchas partes. Buena suerte con el carro.
Guys. We've found him. We've found Waldo. But seriously, cool car man! An Olds 350 Rocket and a TH350 will swap right in. 260/Th200 out, 350/350 in. Simple as that. But it might be easier to do a Chevy because the parts are more available. With the rust around the window, just carefully take all the trim off, the vinyl top will probably rip if it it isn't already, and take the window out and repair it like normal. A car window repair shop or a body shop could do this for you.
Hi Waldo,
Speedway motors, umi performance, bmr, jegs or Summit will have the bushings and bolts. Shipping might be a challenge, good luck with your project!
THere is, but the plastic is so old it will probably just break anyway. Gbodyparts.com sells new clips but I don't know if they ship to South America. A .040 bore with the crank cut .030 seems like it's been built up a little. Seems like a good deal if you can get it for cheap.Here offer me a 350 rocket in 040 bore oversize and 030 oversize in crankshaft, its ok?
Exist a tool to remove ther trim without brake or loose any piece?
Waldo
Hi , thanks, the earthquake are in the south of Chile , I live in center of Chile in Santiago , earthquake for Chilean people is a normal situation....in 2010 the earthquake has a real big....Welcome to the forum, I hope you are ok after that earthquake. I read where you live your city lost power.
