So this came up for sale kinda locally... The lord is tempting me....
Log into Facebook
Log into Facebook to start sharing and connecting with your friends, family, and people you know.
www.facebook.com
It can sit on jackstands for as long as I want.Better hurry up... Winter is almost done.
No pressure.
PS. You can always leave the hood off.
Its an oil accumulator. There are a few reasons to run one. Pre-lube on startup, pushing high pressure oil into the motor if the oil pump starves at launch or in cornering and adding capacity.Information for the uninformed,
What is the purpose of that accumulator? Coolant if you pop a headgasket or? I have seen them and am clueless to their purpose.
You can operate it manually or with a solenoid valve.Makes sense, I like the idea of a lube accumulator. How does it hold pressure when the engine is off? Just trying to understand how it can not bleed off pressure when it sits while still allowing oil to go in the lube circuit in the engine.
Lol, I implied want as it would be my own laziness that prevents it running. I'm getting after it!Want or need? No one wants their car on jackstands.
I am going with the spanish control system, El Manual. Open prior to start for pre-lube and closed unless high G maneuvers are expected. I thought about electric but I don't think it would be fast enough to respond.You can operate it manually or with a solenoid valve.
There's a Piston sealed with compressed air on one side.
Manually you open valve before starting car and close before shutting off.
Electronically via solenoid works the same way but easier obviously
Electric would be fine. Think about it. Say it's got 60 psi of pressure when off. Activate with keyed ignition or switch in car. When you activate wait for oil pressure to build then fire up engine. It remains open entire time protecting internals. When you shut down you will lock in whatever pressure you had. At least that's the way I've seen it work.Lol, I implied want as it would be my own laziness that prevents it running. I'm getting after it!
