all the more reason not to run an LS..Time to cut that tab off and glue it on in the right spot. You LS guys are spoiled, I’ve had to modify sh*t like that on nearly everything for my BBO 455.
The tab is minor. I'm going to P clamp it to the head.Time to cut that tab off and glue it on in the right spot. You LS guys are spoiled, I’ve had to modify sh*t like that on nearly everything for my BBO 455.
I have a single injector low ram base on the way. F(*^ this 16 injector BULLS@&*. I'm done...
You mean my supercharger base?!?Did someone say something about heavily discounted parts?!
I'll probably still have to bend it, however this will solve 2 or 3 other problems down the road. I had a potential injector problem that I want to avoid later.I wasn't kidding about bending the dipstick tube. If you bend it then you can get it out from behind the head and have it between the motor and the passenger side fender. My son's is between the head and the firewall and that thing is a pain in the c*ck to get in, get out, and work around. I attached his with a p-clamp to the one of the holes on the rear of the head. Mine, bent as I described, doesn't interfere with anything.
Keep the faith.
Got the passenger side A arms on and roughed in the alignment.
View attachment 191170 View attachment 191172
I just got camber roughed in, and kinda got caster ballpark. Car isn't level and at ride height totally so I'll have to fine adjust. But so far I'm happy.
Put the wheel back on and I think it's a win. See a little 6 piston sexiness through the slots.
Quick update for sunday.
Drivers side front suspension is in.
Need to swap the Proforged steering parts, UMI GP brace and swaybar then on to the rear.
Out with the stock goodies. Up they go for sale.
