I agree with everyone, that I hope this won't be the end of this..... all the major work has already been done, and would be no more than just a simple engine swap... don't let all of the hard work go to waste!
Me three. I've seen these in the UP&P, but I keep rolling on in search of Gs.You can't give up now. Those engines are a dime a dozen and the concept is still cool. I would give you a hand myself if I was a little closer.
.And how fast did you get with the top end run before the knock started?
Like he said. Get a front wheel drive engine and switch the rear wheel drive stuff over. The Grand National guys have found the 3800 is far superior to the older 109 blocks. 3800 have cross bolt main caps, roller cam, and higher nicle blocks. They take boost very well from what I have read. Only problem are the stock pistons will break at the top ring groove and the forged pistons are pricey. O and no one makes turbo headers that will fit our cars. I have a low mile engine I would sell you if you were closer.Since you already have a top end, you can get the short block out of a FWD 3800 and move all your stuff over. They are much more plentiful than the RWD ones.
